Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Shouldn't the watchpoint default to being on top of everything else?
1 REPLY 1
mcw0
338 Views, 1 Reply
A watchpoint is created to see the data.  Why bury it under all the other nodes?  Especially how cumbersome it is to work with the graph.  Once you have nodes laid out, you really don't want to have to move them to see the data.  If you want to keep the watchpoint while adjusting other nodes, then maybe a semi-opaque mode for the watchpoint so nodes under it can be seen and moved?  But seriously, it shouldn't be buried by default.
1 REPLY 1
mjcg91
in reply to: mcw0
The current watchpoint is not super friendly to use around nodes, and it has some limitation on what values it can display. A better watchpoint will be available in a future version (see Bifrost vision series video).
If you want a detailed view of an object's data, you can use a dump_object. It write all the data contained inside an object on a text file.
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
