Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
[SHARE] Bifrost procedural pie chart ver4.
2 REPLIES 2
g2m.agent
328 Views, 2 Replies
1. install
This package has multiple compounds, some are useful, some are useless, I can’t confirm, so you need to unzip all the files in the package to the same directory. Such as
C:\Users\g2m.agent\Autodesk\Bifrost\Compounds\G2M_compounds
In addition, HSV to RGB by uxusjbh9 is also required.
https://area.autodesk.com/downloads/hsv-to-rgb/
2. How to use
In most cases you only need pie_chart. pie_piece can also be used, but only a piece of pie is generated, and there is no color. others are the "library files".
piece_value_sequence
The number and proportion of pie. assuming you have 10 sheep, 15 cows, and 7 camels, enter:
10, 15, 7
Three pieces are generated, the ratio is 10:15:7.
full_moon_angle
The angle of full pie. you can only use half a pie.
per_90d_sides
The sides number of the polygon every 90 degrees. larger value means smoother.
inner_radius, outer_radius
Radius of the inner and outer ring.
gap_width
The interval between pie pieces.
extrude
extrude height.
Export_Mesh
Whether to output mesh. you can't see anything if I don't check it
color_seed
Random color seeds. this random color does not seem to "random", there are always repeated colors. I hope the next version will be improved.
is_ranbow_color
Replace random colors with rainbow colors
use_per_piece_attr
Use different settings for each piece. after checked, you need to set the parameters independently for each piece.
per_inner_radius_sequence
per_outer_radius_sequence
per_gap_width_sequence
per_extrude_sequence
The inner, outer radius, gap width, and extrude values of each piece. it works like piece_value_sequence. Suppose you want the first inner ring to be 0.5, the second 1.0, and the third 0.8, just enter in per_inner_radius_sequence:
0.5, 1, 0.8
You don't need to enter the value of each piece, the system will automatically repeat the last value. Suppose you have three pieces, and you enter in per_inner_radius_sequence:
1
then the inner_radius of all pieces will be 1.
per_angle_factor_sequence
Used to make the progressive animation of the pie. 1 means full pie, 0 means empty pie.
The specific usage is the same as above.
use_node_as_input
After the checked, the above method of directly inputting parameters will be invalid. at this point, you can connect the parameters of each piece in the Node Editor.
2 REPLIES 2
g2m.agent
in reply to: g2m.agent
version 4.1
fixed a few glitches, and color can be specified manually.
Tips:
Each piece is a separate object and can be packaged into the MASH network.
g2m.agent
version 5.3
* Optimize the input method.
* Color information can be passed to the vertex color.
* Some minor changes.
Basically, it's easier to use.
