Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Set smoke color from a texture map.
10 REPLIES 10
Message 1 of 11
rstefan
987 Views, 10 Replies
I wonder if is possible to colorize smoke using the same texture from the input geometry.
10 REPLIES 10
Message 2 of 11
stamatk
in reply to: rstefan
Hi @rstefan
Since Bifrost does not yet support the import of image textures, the only way to do this would be to bake the texture onto your geometry as CPV data in Maya, and then use that in Aero to color the smoke.
Sorry for the inconvenience.
Thanks!
Kosta
Konstantinos Stamatelos
Bifrost FX Product Owner and Designer
Message 3 of 11
rstefan
in reply to: stamatk
Hi Kosta
Thanks for your reply! Can you look at the attached image, I think I missing something - the smoke color is still black.
Thanks!
Message 4 of 11
stamatk
Try this:
On the aiStandardVolume click on presets and set it to default_bifrost_aero
Break the connection you have between aiUserDataColor and the scatter color. You don't need this.
Since you named your custom property "color" (make sure this is a float 3) just type in "voxel_color" for the Scatter Color Channel on the shader
Also FYI, if you did want to drive scatter color using a user data node, in this case you would need the aiVolumeSampleRgb because this is a volume.
Finally, remember the colors will  now show in the viewport, only in the arnold renderview.
Kosta
Message 5 of 11
mg6083703
Am also need the smoke color in my texture art and want to make  my web design in an amazing way . Would you please help me regarding to this
Message 6 of 11
stamatk
in reply to: mg6083703
Hi @mg6083703
As mentioned above, unfortunately textures are not yet supported by Bifrost. You must bake the texture into the source geometry CPV in Maya, and use that CPV map as color for the aero source.
Thanks!
Kosta
Message 7 of 11
rasskot8CDN7
Hi. Thank you for the detailed reply. Unfortunately none of these techniques work. It is straightforward but for some reason it just doesn't work. Did you try this way with maya 2022 or 2023? It works with particles but smoke is always black. Typing in numerical values  gives you  colours for each channel but that's about it. What I have tried is painting color vertex,  not using a texture map to transfer it. But that shouldn't matter I guess.
Message 8 of 11
sepu6
There is a couple of things that you need to make sure of in order to make this work. I recorded a little video to help you out.
Message 9 of 11
rasskot8CDN7
in reply to: sepu6
Thank you so much for this!
Message 10 of 11
rstefan
in reply to: sepu6
Thank you very much SEPU6 for taking the time to record a video tutorial. I will open the attached scene as soon as I have some free time.
Message 11 of 11
rstefan
I confirm that it works but only in Bifrost 2.4. Thanks to everyone for their help. This thread can be marked as solved.
