Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Set instance geometry - Switch between instance and preview geometries
3 REPLIES 3
braden99
403 Views, 3 Replies
If you plug high res geometries into instance_geometries and low res into preview_geometries port of set_instance_geometry node, It would be very handy if  you could toggle between low or high res mode.
It doesn't feel right needing to connect and disconnect ports to change the display mode.
3 REPLIES 3
mspeer
in reply to: braden99
Hi!
Please insert an "if" node between the shape node and the "preview geometries" input , this allows you to toggle the preview object "on" and "off" by changing the bool value ("condition") of the "if" node.
braden99
in reply to: mspeer
Yep adding an if node does the trick.
I was expecting the set_instance_geometry node might be high level enough to also include this switch. But the Bifrost nodes seem more granular so far.
mspeer
Hi!
You even would not need to connect the main instance geometries to the if node (but you can do if you want).
If no input is provided to the preview geometries then automatically the main instances should be used.
