Set an object to its UV flatten shape
TasticAd
TasticAd
Hi everyone,
I'm quite new to Bifrost but pretty sure this is a possible thing to realise within it (hopefully it is)
Like the title says I'm trying to unwrap an object to its UV shape 👨‍🔧
My first approch would be to get the geo's face_vertex_uv property but then can't figure yet what should be used between the get_geo_property and set_geo_property nodes... Any hint would be appreciated 😊
mjcg91
I made a compound for this a while ago, you can have a look inside to learn how to create the flattened shape from the mesh's uv properties.
Cheers
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
Christoph_Schaedl
Thanks does work great!
https://linktr.ee/cg_oglu
TasticAd
Thanks mjcg, that's a nice compound!
I managed to find a solution for my needs, I actually wanted to create a transition animation like so:
I could in fact export the mesh as flatten for this particular model. Then I used a linear_interpolation between the to meshes point_positions.
I will have a look further into you great compound and see if I can do the same with other kind of models (if it keeps the same vertices order, it would be great!)
abercaine
hi,
is it possible the other way around?
Basically going from a flattened mesh to actually create UVs to feed another mesh
