Announcements
Scale particle emission rate using vertex color
ken.ootani
ken.ootani
I have edited "simulate_particles" compound.
you can use a vertex color to scale the "emission rate" and "initial velocity" on parts of the surface.
I expect Autodesk to support texture maps in the future.
khanwars64
a vary_source_properties could do the same thing  with color set , as u said down side is texture maping-
but i liked what u did with other nodes however i dont understand it attall :)))
it would be nice if u explain logic behind your  graph  why there are values why there are set and get  in a word why nodes are there
and yes for sure this bifrost need lot more tools and utilities to get in work
for now i think practicing is kinda waste of time
ken.ootani
I understood " vary_source_properties" .
I edited "simulate_particles -> solve_particles -> advance_one_frame -> advance_one_timestep -> emit_from_source -> emit -> create_points "
ken.ootani
example1 : use the feedback port .
example2 : use influence
example3 : edit simulate_particles
