I have edited "simulate_particles" compound.
you can use a vertex color to scale the "emission rate" and "initial velocity" on parts of the surface.
I expect Autodesk to support texture maps in the future.
Link copied
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
a vary_source_properties could do the same thing with color set , as u said down side is texture maping-
but i liked what u did with other nodes however i dont understand it attall :)))
it would be nice if u explain logic behind your graph why there are values why there are set and get in a word why nodes are there
and yes for sure this bifrost need lot more tools and utilities to get in work
for now i think practicing is kinda waste of time
I understood " vary_source_properties" .
I edited "simulate_particles -> solve_particles -> advance_one_frame -> advance_one_timestep -> emit_from_source -> emit -> create_points "
example1 : use the feedback port .
example2 : use influence
example3 : edit simulate_particles
