Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
"vdb_influence" BUG
2 REPLIES 2
Bruce.Lee.
365 Views, 2 Replies
"vdb_influence" BUG
When I made a VDB speed field in maya or houdini and imported it into Bifrost, the name of the speed field will be renamed to "voxel_velocity". But "read_vdb" reads the original velocity field name.
Simply put, if the VDB speed field is output in Houdini or other software, if the name of the speed field is not "vdb_influence", then the "vdb_influence" node will have no effect.
There are only two ways. 1. Change the name to "vdb_influence" when outputting the VDB speed field in other software. 2. Change the node structure inside "vdb_influence" and let "read_vdb" read the original name.
2 REPLIES 2
Bruce.Lee.
in reply to: Bruce.Lee.
I uploaded a file containing two VDB files, one named "vel". One is "voxel_velocity". Only Vdb files named "voxel_velocity" can make a difference.
stamatk
Hi Bruce, thank you for the files!
We're looking into this issue.
Konstantinos Stamatelos
Bifrost FX Product Owner and Designer
