Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
procedurally driving size of array in value node
2 REPLIES 2
mentalspoon01
578 Views, 2 Replies
Hi All
Is it possible to procedurally driving size of array in value node. I want the array size to know how many points are on the incoming geometry?..
Many thanks
Mark
2 REPLIES 2
mjcg91
in reply to: mentalspoon01
You can't directly change the size of your array inside the "value" node. What you should do is use a "resize_array" in order to procedurally drive the size of your array.
In your case, you want to use "array_size" before "resize_array".
Alternatively, you can simply use "get_point_count" with "resize_array" as such:
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
I will try that.. Many thanks
