Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Plane Orientation to Aero Initial_speed_direction
12 REPLIES 12
Message 1 of 13
kill3dge
416 Views, 12 Replies
Hi!
I have a problem, I've created a plane, rotate it and imported to the Bifrost Graph, but when I create basic aero simulation the smoke goes upper, and I wanted him to burst according to plane orientation, any ideas?
Thanks in advance!
12 REPLIES 12
Message 2 of 13
sepu6
in reply to: kill3dge
Here is one way - just remember there is more than one way to do stuff.
Message 3 of 13
kill3dge
in reply to: sepu6
Thanks! This is what I've been searching for!
Message 4 of 13
darioOrtisi
Hi @sepu6
Is it possible that seomthing change on version so your scene doesn't work anymore? There are no errors, but the voxel field doesn't affect vector scope.
Message 5 of 13
darioOrtisi
Ops sorry i did a mistake. All works fine. my bad.
Message 6 of 13
duqdl94
in reply to: darioOrtisi
I'm also experiencing the voxel field node not working.
what am i missing?
Message 7 of 13
darioOrtisi
@duqdl94  activate terminal?
Message 8 of 13
duqdl94
Yes, I activated the terminal.
I was able to confirm that it works without any problems when I open sepu6's example scene file.
However, when I create and connect a voxel field myself, nothing works.
I find this situation hard to understand.
Message 9 of 13
darioOrtisi
Interesting. Try to add a vector_field node on vector_field connection of your voxel_field
Message 10 of 13
duqdl94
Oh, it's working!
Thank you so much.
Message 11 of 13
darioOrtisi
in reply to: duqdl94
Good to know. Maybe we have found a bug. Or it is normal. In fact i use to add a vector_field everytime. Try to disconnect and look what happen? IF it remain equal or doesn't visualyze anymore.
Message 12 of 13
sepu6
It is not a bug, it is the way that the node is supposed to work, by default when you drop a new voxel_field node it outputs scalar/float values you need to make sure what kind of data is coming in and change the port accordingly.
So what is happening there is when you drop a new one just and you just copy the property to the new voxel field node doesn't know that is supposed to be a vector type. Again because by default it reads scalar data.
Message 13 of 13
darioOrtisi
in reply to: sepu6
Perfect
