Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Particle self attract/force field?
4 REPLIES 4
InNeedOfHelp
548 Views, 4 Replies
I'm trying to simulate particles gravitating towards each other, similar to what you can do with nParticles and their force field attributes. I tried simply getting the particle position and plugging that array into a radial influence. It works but is impractically slow, so I'm trying to find a more efficient solution. If anything a way to cut out the file caches,using those were the only way I could think to get the output particle position in the radial influence without an error.
4 REPLIES 4
mjcg91
in reply to: InNeedOfHelp
I don't think the radial influence is meant to be used like this. The way you are using it create 1 radial influence per point, which might cause an overhead.
You should try to use the attract_repulse_influence.
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
InNeedOfHelp
Unfortunately attract_repulse_influence wasn't accurate enough for what I was trying to do, although I did eventually find a solution. For anyone who's curious I'll attach the scene file. Inside simulate_particles>solve_particles, I added some nodes to calculate the force of gravity from each particle and then set the particles velocity from that. If there's a more user friendly way to do this, like making a node I can plug into influences or something rather than having to modify the simulate_particles node, I'd love to know about it.
to-to-ro
We need to wait get_points_in_radius node from dev team.
I think its hard to impalement desired effect without it
Anton Kalchenko
I hope we dont have to wait too long for some raycast nodes.
https://linktr.ee/cg_oglu
