Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
NUMA nodes scalability
2 REPLIES 2
davide445
289 Views, 2 Replies
Due the limitation of my workstation CPU was testing Bifrost MPM on cloud VM.
So far as a test is working fine, but to substantially improve speed will need to use 32 - 48 or 64 cores machines, that are designed as 1, 2 or 4 NUMA nodes.
Wondering if using more than 1 node will substantially lower the speed scalability in Bifrost simulation.
2 REPLIES 2
davide445
in reply to: davide445
Looking better at the specs with AMD CPU the expected nodes are
32  core - 4 NUMA nodes
48 - 6 NUMA nodes
64 - 8 NUMA nodes
96 - 12 NUMA nodes
With Intel CPU we have
32 core - 1 NUMA node
48 - 1 or 2 NUMA node
64 - 2 NUMA node
72 - 2 NUMA node
There are official CoreMark benchmarks but not sure if they are relevant for Bifrost MPM sim, the bench seem not being impacted from NUMA nodes count.
davide445
I have done some tests on Azure standard (not dedicated) instances F64, D64, D32, D16, HB120
Seems having 16 or 120 vCPU (threads) available make little difference
On my Ryzen 6 core CPU I need about 30 sec to generate every frame
On all these instances I need btw 55 sec to 1 min to do the same
CPU usage range from 85% (16 vCPU) to 60% (64 vCPU), but in all cases in 1 min of work there is 10-15 sec of max CPU usage and next all the time on single thread activities
Attached the average usage profile.
This is way different than on my Ryzen CPU where the full CPU load is much more extended.
Wanted to ask what's in your experience the right balance to find max performance: need I to use a dedicated server or a simple 6-->12 core local CPU upgrade (also different generations) will in fact be the best.
