Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Not getting random values...Bifrost 2.0.1.0
4 REPLIES 4
mcw0
251 Views, 4 Replies
I'm trying to get random vectors.  My "value1" is a <<Math::float3>>.  My random_value_array size is 1.  I have the exact same thing only with a float value and it works.  Why does my watchpoint have no data?  And why if I add this to another vector cause there to be no values?  Shouldn't it at least have my normal vector as the resulting value?
4 REPLIES 4
sepu6
in reply to: mcw0
Is working correctly here. The first thing I would do is update your BF version. You are using a pretty old version.
mcw0
in reply to: sepu6
Tell me about it.  The studio I'm at is stuck in Maya2019 and won't update anything until they update Maya.  😞
I found a workaround by using noise functions.
morten.bojsen-hansen
in reply to: mcw0
@mcw0, It looks like you might not be pulling on the output of random_value_array. Can you double check that the output is connected to an output node through some chain of nodes?
mcw0
in reply to: morten.bojsen-hansen
I'm definitely pulling data from that node.  I know it's old version of Bifrost so it's probably been fixed.  It's unfortunately the version I have to work with.  But I have a workaround.  Thanks
