Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
MPM emitter
2 REPLIES 2
doppelgaenger_digital
343 Views, 2 Replies
MPM emitter
Is it possible to make a custom emitter, or a particle emitter for MPM cloth? Right now I can only turn geo into mpm_cloth once the start frame is reached. And I just can't hook up make_mpm_cloth inside for_each loops.
Is there a way to do this?
2 REPLIES 2
This is quite easy using an iterate or for-each loop. You just need to make sure that you feed an array (NOT a 2D array) to simulate_mpm. With iterate, you can use a state port with build_array. With for-each, you can get the first element in array out of the cloth_source array, so that each iteration outputs a single objects (you are limited to one object so I recommend iterate instead).
Here is an example which continuously emit planes every 3 frames. It emits as much as plane as the number in max_iterations.
Bonus: it also apply a material with random color to each plane 🙂
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
yesss. thanks maxime! I got it working! Didn't think about using iterate. Now I must get my head around fully understand what's going on 😄
Technology Administrators
