Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
MPM display particles velocities by color
2 REPLIES 2
davide445
388 Views, 2 Replies
Trying different paths to achieve this result by so far with no luck:
1) simulate_mpm(granular_particles) --> split_points_by_material(snow_particles) --> get_point_velocity( point_velocity) --> (base_color)standard_surface_material --> assign_material --> output
2) simulate_mpm(granular_particles) --> split_points_by_material(snow_particles) --> set_color_by_property(out_points) --> (geometry)assign_material --> output
3) simulate_mpm(volume) --> extract_property (velocity) --> same as before
For sure I'm not getting something basic.
Labels (3)
2 REPLIES 2
JMM71
in reply to: davide445
This video shows a workflow for transfering velocity to color.
https://youtu.be/YcoiWD1O0Xk
Hope it helps
Jason
davide445
Discovered I can obtain similar effect easilly using "assign_diagnostic_material" or "point_scope" nodes.
The only problem is resulting particles have just a base color with no shading so it's difficult to distinguish them.
Wondering if there is a way to add some other property such as roughness or specular.
Technology Administrators
