Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Missing source_air from source_fuel's input node in Maya2022
3 REPLIES 3
kemenyz
362 Views, 3 Replies
Missing source_air from source_fuel's input node in Maya2022!
Maya 2020:
Maya 2022:
Or is there a way to get it back somehow?
3 REPLIES 3
kemenyz
in reply to: kemenyz
Aah, I see, the order was changed:
Although I don't know where can I plug in the geometry source:
calibrix
Hi @kemenyz
There's been quite a bit of BiFrost improvements over the past year. Fuel is sourced a bit differently now as you've seen. Source_Fuel connects to the additional_properties input and does exactly that: adds the additional (and necessary) properties for combustion. It uses the same input from the source_air node and generate the fuel properties from that input. See the example screen shot attached.
kemenyz
in reply to: calibrix
Thank you!
