I am not seeing the Scatter_points node
Hi!
There is no scatter_points node in Bifrost.
Maybe you are referring to the Rebel Pack, which can be downloaded from here:
https://area.autodesk.com/downloads/rebel-pack-030/
But you can also create your own scatter network by using generate_samples_location + sample_property + construct points.
Hi Mspeer,
Thanks for quick reply, I had installed Rebelpack before. But Maya 2020 update 3 was a fresh install, so it wiped out my Bifrost folder, thus missing rebel pack. I reinstalled it.
There is a video by Steven rosvelt? creating own scatter compound, which you have mentioned too.
Thanks a lot.
