Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Mash points line connection with Bezier curve
4 REPLIES 4
bmaQLUCD
307 Views, 4 Replies
Hi folks,
I'm trying to make a line graph like this: https://openprocessing.org/labs/opviz
My idea is to generate a group of points with Mash, then use Trails node to generate connection. However, I want the lines to be curve lines, just like the way Maya's node graph looks. I'm wondering if this can be done in Mash or Bifrost graph? Attaching a screenshot to demonstrate the kind of node graph I'm trying to make.
Thanks in advance!
Labels (4)
4 REPLIES 4
ihooper
in reply to: bmaQLUCD
Perhaps the information in this post will be helpful?:
https://forums.autodesk.com/t5/bifrost-forum/droopy-strands/m-p/10459363
There is also this compound which could be useful: https://area.autodesk.com/downloads/catenary-curve/
Ian Hooper
UX Architect
bmaQLUCD
Thanks for the quick reply! I just saw this post and it looks promising!
andrew.bkly
Hey there I did the droopy strands one also MJCG's compounds has some to create different curves as well.
My droopy strands one is very simple, catenary I think is more accurate for a type of curve but to do what you're trying to achieve you might have to mod droopy_strands so each strand projects toward the centre of your circle and not just down in Y. But it should connect all your points with lines and everything.
bmaQLUCD
Thanks a lot @andrew.bkly ! Appreciate the help. I'll look into it and see how it goes.
