Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Magnetic Field anyone Bifrost Graph?
2 REPLIES 2
darioOrtisi
372 Views, 2 Replies
Hello.
Does someone able to reproduce this magnetic Field in Bifrost Graph?
https://www.youtube.com/watch?v=kwZig5W7Pwk
2 REPLIES 2
PhilRadford
in reply to: darioOrtisi
As with anything like this you have to think about it for a bit and then just realize that it doesn't have to be so complicated. As an artist I look for the most creative approach first.
There are many ways to do this and it depends how deep you want to go and what works best for your level. If it was me I would always start simple and work up from there. Maybe scatter some small spheres around a big sphere first. The small spheres will be emission. Create strands from the surface normals of the small spheres. Create a an mpm fiber network. Use the small spheres to constrain the strands (so they don't fly away) switch off gravity on the solver. I would then again use the small spheres as 'attract repulse' influences. Your strands will need to be sampled well for this to work. Your attract repulse should be set to attract but with very small numbers and maybe add a small turbulence influence too.You just want those strands to bend a little in an arc. Play around with the settings until you get a result that starts to look like the link you sent. I don't have the time right now to make an example but if I find the time tomorrow I will.
darioOrtisi
in reply to: PhilRadford
Hi Phil.
I 've asked a lot a time ago into soup-dev forum And Peter helps me.
I will like to know if there was seomthing in the graph with field.
