Level set and point_radius
salvati.marc
salvati.marc
hello everyone,
im trying to vary the radius per particle when using level set without success.
the global radius parameter of the level set node doesnt seem to work either.
if someone has ideas on how to use it. please help
i attach the network and maya files.
Thanks for the help
salvati.marc
couldnt attach the maya file... attaching a zip archive instead.
morten.bojsen-hansen
The name of the property is point_size - not point_radius.
salvati.marc
thank you!
you re right....
the documentation has to be changed  i guess.
Thanks! I will make sure to update the documentation!
