Legacy Bifrost Aero - Blocky renders
jeremyraven
jeremyraven
Hi there,
Bifrost Aero noob alert!
Ive been playing around with the legacy aero but cant seem to get any nice renders out of Arnold. Ive tried reducing the render voxel resolution on the bifrost node and the render settings inside Arnold but I still cant get a nice smoky look - Im thinking its more the shader than the aero nodes, can anybody help?
Also while using the aiStandardVolume, it doesnt show up in the viewport as a volume when voxels is selected instead of particles on the aero shape node. If I exchange that shader for the bifrostAeroMaterial one, it does show up in viewport but Arnold doesnt seem to be able to handle that shader at render time.
michael_nielsen
When you create a Bifrost Fluids Aero simulation, it is already set up correctly with an aiStandardVolume as shown in the attached image. You can use this aiStandardVolume to adjust shading parameters and render with the Viewport, Arnold etc. I noticed in your screenshot that among other things the names of the smoke and temperature channels were not correct on the aiStandardVolume. Note that these are named differently from the smoke and temperature of the aero solver in the Bifrost Graph. Hope this helps.
Cheers,
Michael
Michael Nielsen
Principal Engineer
