knit animation in bifrost graph
hi all,
i have been am trying to redo the attached simple knit animation( i did with mash) but i have no idea how i would approach it on the bifrost graph.if any one has any idea of how to do it kindly share.
kind regards,
Mike
triction7070
Hello Mike, how did you approach this with mash
Christoph_Schaedl
Have you seen the strands braid example scene in the MJ compounds?
They could help.
https://linktr.ee/cg_oglu
Thanks for the tips . will give it a go and see if it will  give the results am going for.
Cheers!
hi,
i used mash merge node...
I knit setup.JPGdistributed the same number points on 2 curves then merged them together.
