Issue rendering Bifrost data using Arnold with permanent Maya 2020 license
BurkhardRammner
Message 1 of 22
BurkhardRammner
Hi...
I'm still on Maya2020 and started to test bifrost.
But no matte what I do, I don't get arnold to render bifrost data.
My bifrost is: 2.2.0.0 and my arnold is 5.2.2.4
So shoud these 2 versions work together?
Thanks for help!
*Title edited for clarity: arnold does not render bifrost*
Replies (21)
Message 2 of 22
Stephen.Blair
You'll need Bifrost 2.4
Help | 5.2.2 | Autodesk
// Stephen Blair
// Arnold Renderer Support
Message 3 of 22
Christoph_Schaedl
I would upgrade Bifrost to 2.7
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/2aZO1BEEN1yOnBswYFuvwz.html
https://linktr.ee/cg_oglu
Message 4 of 22
BurkhardRammner
Ah, thanks...but obviously I cannot update to a newer bifrost version.
I meant, I could not find any option to update...
Message 5 of 22
Christoph_Schaedl
The update is in your Autodesk account.
https://manage.autodesk.com/home
Message 6 of 22
BurkhardRammner
I cannot find it...
Message 7 of 22
Christoph_Schaedl
All products --> Maya --> Extensions
like in the image above.
Message 8 of 22
BurkhardRammner
Message 9 of 22
Christoph_Schaedl
Looks like you don´t have a Maya license on this Account.
Use the one you are using to start Maya.
Message 10 of 22
BurkhardRammner
When I click on 'zur klassischen Ansicht wechseln', then there`s my Maya license...but still no option to download bifrost.
I tried out everything..no success..
Message 11 of 22
Christoph_Schaedl
Are you on a Student license?
If yes, you need to renew it and download Maya 2024.
Message 12 of 22
BurkhardRammner
the downloads tab:
Message 13 of 22
BurkhardRammner
I have a 'normal' license from 2020:
Message 14 of 22
Stephen.Blair
I don't see anything in the backend system for the account I found using your username as a search. Not even that Maya 2020 license (is it a permanent license, with no current maintenance? that would explain why there are no products listed, and only something under classic view)
// Stephen Blair
Message 15 of 22
BurkhardRammner
Stephen,
yes, its permanent.
Message 16 of 22
BurkhardRammner
it was the last Maya version I bought....which probably means 'without current maintenance'
The arnold download archive was obviously killed by AD, so I cannot test if older arnold versions would work..seems I'm stuck now : (
Message 17 of 22
Stephen.Blair
The download archive was not killed. Contact Autodesk Support for downloads. The Autodesk Account portal doesn't seem set up to handle users with no subscription or maintenance. At a minimum, you should be entitled to whatever was available at the time the maintenance contract expired.
// Stephen Blair
Message 18 of 22
BurkhardRammner
thanks Stephen..will do.
Message 19 of 22
Stephen.Blair
I guess I would say: I have a permanent Maya license, but Maya doesn't show up under All Products and Services, or under Product Updates.
So I cannot access the Extensions downloads. I need to download MtoA and Bifrost for my Maya 2020.
And then specify what versions you want. I don't think they'll be able to fix up your account so that you see all the available MtoA and Bifrost versions, so they'll generate download links for you.
// Stephen Blair
Message 20 of 22
BurkhardRammner
thank you!!
