Is there a way to "jump over" once loop? something like the "continue" keyword in Python.
g2m.agent
g2m.agent
for i in some_array:
    if i==0:
        continue
    # do something that i not equal 0.
Grahame_Fuller
Connect your array to a for_each compound. Inside that, right-click and make the array connection into an iteration target. Delete the max_iterations port (or set it to a large number). Use an if node to test whether the current value from the array is 0. If it is, pass it through unchanged. Otherwise, change it in some way.
I hope that helps,
gray
Grahame Fuller
Learning Content Developer
