Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Instancing group of objects
16 REPLIES 16
Message 1 of 17
salvati.marc
1377 Views, 16 Replies
Hello everyone.
I m trying to instance objects using set_instance_geometry.
First trial with  single objects works well.
But when using objects composed of multiple objects (tree + leafs, flower + petals ...) then it becomes tricky.
I tried to use the merge node before sending to the set_instance_geometry node. It did work, but the shader of both objects are lost.
I tried to use build array node, thinking that an array in the instance list would be considered as a whole, which is not the case.
So another solution would be to use multiple set_instance_geometry nodes with the first part of each object, then the second... and use always the same points data for each instancer. but if objects dont have the same number of parts we have to add dummy objects...
I thought about another solution, just use set_instance_geometry with only one object, one id. Instanciate each part of each object separately, and just use common points between objects from the same part.
I wonder if what i try to do is clear... Maybe there is much simpler ways to do that.
if anyone has any ideas...
Thanks in advance.
16 REPLIES 16
Message 2 of 17
Hi Marc,
This is something we're looking to improve in the future. For the moment, if you want to instance an asset composed of multiple objects, your best bet is to instance render archives (AKA: .ass files).
These have some side benefits, such as supporting the entirely Arnold feature set and time offset instances.
To do this, export an Arnold .ass file and use the "render archive instance" node.
Jonah Friedman
Bifrost Product Manager
Message 3 of 17
thank you for your answer. i didnt thought about it, but yes that is a possibility.
do you have any ideas between the performance difference in rendering/memory using ASS for group of object  VS using as many instancer as there is part in the object?
Message 4 of 17
I accidentally clicked "accept solution" just now, please ignore that 🙂
There should be no real performance difference - it's kind of all the same to Arnold whether the geometry was translated from Maya or whether it loaded from a file. The geometry will need to load from disk at the start of the render, but this tends to be fast. Your scene file can be faster to load by not containing the geometry.
Jonah Friedman
Message 5 of 17
ok. i ll try both and compare. If i dont need to go through ASS, it simplifies the workflow.
Message 6 of 17
can we now instance multiple objects without using ASS files?
This seems like it should be crazy simple. IN houdini simply get a merge node and plug two objects into it. 3 nodes... that's it.
Node basics 101.
How can I combine multiple objects together with different shaders and then instance them all at once?
Message 7 of 17
Only if you use USD files.
https://linktr.ee/cg_oglu
Message 8 of 17
is there a way to select a single point from the bifrost scatter and delete it?
Message 9 of 17
You cant select it by clicking. But you can cull it with an object in the graph. Or paint a mask.
https://discord.com/channels/872260298508222534/1152218612296327190/1153288472027725904
https://youtu.be/aGziWy39XU8?si=f1mb5s5j15KG5oY6
Message 10 of 17
I don't know if it can be a solution, I used an "iterate" to create instances for each object in the group.
Message 11 of 17
thank you, can i see one level up? not sure where this is feeding into from?
Message 12 of 17
Message 13 of 17
thank you very much and sorry for the misinformed question
... but where are you're multiple objects feeding into? 'input by path'
what is that and how are your multiple objects going in there?
thanks again
Message 14 of 17
don't worry, sorry me if I didn't post a scene.
you can drag your selected objects from the outliner and import them into the graph
Message 15 of 17
I understand but how are you combining mulitple objects with different shaders?
Are you dragging them in as a group? I can't seem to be able to do that.
Are you merging the geo somehow?
Message 16 of 17
I tried an example with 3 different groups. I don't know how manageable it is.
I hope it can be useful.
Message 17 of 17
sorry for the double post, I changed the scene.
