Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
I cannot republish my compound
1 REPLY 1
g2m.agent
248 Views, 1 Reply
I cannot republish my compound.
I revised my previous work, it basically removes a terminal node and some nodes connected to it.
when I republish it, it prompts for this info: Existing compound is not overloadable (it is locked).
check the "Overloadable", did not work.
I restart Maya and still did not work.
1 REPLY 1
g2m.agent
in reply to: g2m.agent
I found a solution.
  1. Save the scene, close Maya.
  2. Delete the existing JSON file.
  3. Open the scene you just saved
  4. Republish
  5. Edit the JSON file just publish and delete the content related to the terminal node. If you don't delete it, this compound will report an error.
  6. Restart Maya and import this compound.
