Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
How to transmit the color per particle property after the simulate particle node ?
4 REPLIES 4
moiamy
569 Views, 4 Replies
1. I have imported particles inside Bifrost (convert_objects_arrays_to_points). I have got color property in the out port?.
2 These go through the simulate particles, but I lost track of this color property. Now the result as an output are grey particles.
How can I transmit forward this color information ?
Fransua
4 REPLIES 4
mspeer
in reply to: moiamy
Hi!
1. I recommend to work in the main graph and not in the second graph created for particle import.
2. Insert a source_particles node before the simulate_particles node.
3. Add "color" as additional property to the source_particles node (additional properties).
moiamy
in reply to: moiamy
Thanks Mspeer. It works great.
I also tried to replace simulate_particles with simulate_mpm, buit in this case nothing comes to screen, even if i plug source_mpm_sand instead of source_particles
mspeer
in reply to: moiamy
Hi!
For mpm the setup is the same, however as source you need a source_mpm node with the additional property "color" added and the simulate_mpm node needs to be connected to an output.
sixty2moons
in reply to: mspeer
So I too am working on relearning this technique using the Bifrost graph, but alas I am stuck. I've attached my Bifrost Graph Editor. Any help would be greatly appreciated. I am still learning the Bifrost system but I do have a bit of experience in node-based programming.
-Joel
macOS 10.14.6 / Maya 2020.4 / 2013 Mac Pro / 64G Ram / 2.7GHz  12-Core
