Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
How to make cold water? Like the waters have smoke effect and some bubbles
1 REPLY 1
juwail
269 Views, 1 Reply
It will helps to make create soda pepsi peso
1 REPLY 1
That's a rather complex setup you want there. 🙂 I can't do all the work for you, but I can give you some hints of where to start. For water, you can use MPM with a source_mpm_fluid to create water. Then you can select some of the MPM particles and use the as sources of smoke in an Aero simulation. For bubbles, you could use a particle system and noise influences to generate motion that sort of looks like bubbles. To make it all look real, you obviously also have to use the right shaders with Arnold. It will take some work, but hopefully that'll get you started. 🙂
