Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
How to increment a value inside iterator or for-each loop
2 REPLIES 2
pranaymeher
445 Views, 2 Replies
Hey guys, I stumbled upon this issue but could not solve it. Basically I wanted to increment a value inside an iterator block or for-each block. I know for-each is a parallel block, so it's not a good choice. I'm also know how to use the feedback ports to update the existing attribute values. But Bifrost errors when I use feedback port inside an iteration block. To simply put it, I want to graph the following python code in Bifrost.
import maya.cmds as MC
value = 5
for i in range(5):
    value += (value/2)
print value
# Result : 33
If anyone knows how to do it then please share with me. Thank you.
2 REPLIES 2
mjcg91
in reply to: pranaymeher
What you are looking for is a port state. It is available in do-while and iterate loom compounds.
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
pranaymeher
in reply to: mjcg91
Thanks a lot for the reply @mjcg91. That's exactly what I was looking for. The naming 'port_state' doesn't make sense but as long as it does what it does, its good.
