How to get "Position" of the "Location"?
g2m.agent
g2m.agent
I know the "Location" is a certain location on the surface of the mesh.
Now I need to know its spatial positioning, such as the value of XYZ.
How to do it?
mjcg91
use sample_property
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
g2m.agent
What "Property" should I use?
the default value is "point_position", I change it to "location_position". It seems not to work.
Most important: where can I find these Property names? on Shape node??
I was unable to find any "location" ports on pCubeShape1.
mjcg91
You can use a watchpoint to see the properties on a geometry object.
point_position is the property you have to use if you want to sample the closest position. More info  the documentation: http://help.autodesk.com/view/BIFROST/ENU/?guid=Bifrost_Common_build_a_graph_geo_query_html
