Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
How to emit smoke from selected points using Bisfrost?
4 REPLIES 4
487 Views, 4 Replies
Hi ..
Is it possible to emit smoke from some points of my selection in say a sphere shape?
if it’s possible, how it can be done?
thanks
Tags (3)
Labels (1)
4 REPLIES 4
Aslan.Jafari
Unfortunately we can't detect a component selection of the DG element in Bifrost, unless the said component  triggers a geometry or property change.
You may simply paint a CPV map on the sphere and extract the painted points via Bifrost.
Extracted points then can be passed to an Aero simulation system to generate the smoke.
I've attached a scene file for this workflow, along with extracting faces from the painted CPV map that could be useful in other cases.
Aslan Jafari
Sr QA Analyst
Hi . it gave me the showing the below error when i use the same procedure
syracoj
right-click on the get_geo_"colorSet1" nodes type port and set the type to array<float3> (maybe array<float4> type) and see if that helps. This can also be done in the parameter editor for that selected node as well.
Yes .. It Worked..Thanks.
Technology Administrators
