How to change vdb grid voxel_fog_density name to density?
a.mayaUser
a.mayaUser
Hi everybody,
when I do simple conversion like using the convert_to_volume or the mesh_to_volume node to a vdb file I always get the voxel_fog_density grid name which I'd like to call just density.
Is there a node to change this default grid name? Or any other property/attribute name, since I'm asking...
sepu6
Set geo property and you want to target the voxel tile tree
a.mayaUser
Thanks @sepu6, but I'm not sure I'm connecting the right way: the set geo property it does indeed create a second grid called density, but my goad is to take the already existing voxel_fog_density and just rename it.
sepu6
if do that you won't be able to see the density field in Maya (in the VP) You can still render it -  if you want to export it as a VDB you can just delete the voxel_* properties with the "erase properties" node and export just the density field.
a.mayaUser
It's just for export as vdb: but the erase properties doesn't fit the purpose, I can't use the already existing voxel_fog_density if I delete it, I just need to change its name for exporting to other sw.
sepu6
Can you show me the graph? what I mentioned above works. I've done it many times. I am not sure what is not working.
morten.bojsen-hansen
