Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
How to change the frame rate of a render sequence to achieve a slow motion effect?
1 REPLY 1
505 Views, 1 Reply
Hi guys, I'm using Arnold and trying to slow down a scene created with Bifrost.
Basically I have a splash happening in 70 frames that needs to be extended to 300 frames. Without changing gravity or Trans Time (i'm happy with the look of the splash), is there a way to render the animation sequence on a higher frame rate? The same 75 frames (3 seconds) on a 300 frames image sequence?
Thanks!
Labels (2)
1 REPLY 1
mspeer
Hi!
Every change of the frame rate or resolution of the simulation will change the look of the result.
You can't simply render more frames than you created during the simulation.
Technology Administrators
