Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
How scale point based on vertex paint with a scatter by number
6 REPLIES 6
john_l_aveugle
174 Views, 6 Replies
Hello everybody,
I'm new to bifrost and I need your help. I ll try to change the size of scattered point with a vertex paint.
I ve tried to use a "get geo colorset" plugged in a "vector to scalar" plugged into weight of a "scale point" with no result.
Any idea
Loic
6 REPLIES 6
sepu6
in reply to: john_l_aveugle
Make sure you are reading the color set correctly and make sure that the data type is correct as well. Usually is float 4. To make sure press W to see between the connections to see what type is it
john_l_aveugle
in reply to: sepu6
Thx for your answer. I'd already tried and setup all the node. It works when connect them into density but I don't know how to setup for my need. Is it possible for you to post here a scene or a tuto to drive a point scale base on a vertex paint ? To drive scale instances. Thx for your help
https://youtu.be/Z_GBXcJNefE
https://linktr.ee/cg_oglu
mmmm thanks a lot, tryed to find this on google with no luck. Now i have to try by myself. Post here my result soon.
T
Take a look here at my tutorial collection. most stuff is there.
https://liamcollod.notion.site/8a4d349be67843e4b2952093157d3ae2?v=201ecb66b17b4df49dd45b2e7b824353
works like a charm 😄
thx a lot team !
