Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
How do I make two different bifrost simulation colide with eachother?
7 REPLIES 7
Message 1 of 8
844 Views, 7 Replies
Yo!
Just watched this on youtube and its exactly what I want to do https://www.youtube.com/watch?v=svTBNWNcNMY
so how do I make two different bifrost simulation colide with eachother? ๐Ÿ™‚
Thanks in advance
7 REPLIES 7
Message 2 of 8
Christoph_Schaedl
Do one sim with two source objects.
https://linktr.ee/cg_oglu
Message 3 of 8
in reply to: Christoph_Schaedl
How do I change the gravity so they meet up? Now they go seperate ways
Message 4 of 8
Christoph_Schaedl
You are using the new Bifrost Graph right?
Or the old fluid system?
Message 5 of 8
The new bifrost graph is correct
Message 6 of 8
Is it possible to set up some kind of focus point?
Message 7 of 8
or do I set gravity to 0 in the liquids cointainer option and add two motion fields of each side of the objects with the same gravity?
Message 8 of 8
joostkonemann
If you have a liquid container in your scene, you're using the legacy Bifrost fluids system.
You can either create motion fields, or set initial velocities on the emitters(listed as additional velocity), depends on the look you want.
In the graph for an Aero or particle sim, you can use influences (e.g. gravity_influence with a mask_influence define the active region of the influence) or initial velocities as well.
MacBook Pro 13,3 - 2.7GHz - 16GB - Radeon Pro 460 - macOS Catalina 10.15
