Generating objects per face
hintzjt7
hintzjt7
Does Bifrost have any functions that'll allow an object to be generated or instanced on a mesh per face like the Micromesh and Nanomesh features in ZBrush? Intro to ZBrush 046 - Use MicroMesh and NanoMesh to create complex surface detail and patterns!! - Y...
sepu6
Rebel package > Disconnect Mesh Faces then if you edit the compound you can output the "face center"
You will get the centroid of your faces as pts then use a Construct point and copy your geo into those pts.
