Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
fractal_turbulence_field offset animation
4 REPLIES 4
takaharu_tobe
260 Views, 4 Replies
hi
I made a cloud.
I was able to animate fractals, but I couldn't do offset(like animations in of after effects noise.)
How can I do it?
Thank you.
4 REPLIES 4
You can plug the noise_field output from fractal_turbulence_field into the field input of an advect_field node, and then supply the velocity_field that you want -- you can use a simple vector_field node if you just want a constant drift.
I hope that helps,
gray
Grahame Fuller
Learning Content Developer
thanks!
i will try.
If you have any issues, please do allow me to discuss it with you.
Hi @takaharu_tobe ,
you can also use „transform_field“ to move/rotate/scale the field.
transform_field is matrix.
It is tough for me.
I was able to move it a little like a cloud.
I'll try my best.
Dear Grahame and Roland
Thanks a lot
