Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
for_each gets the wrong sequence, some values are right, some are wrong.
2 REPLIES 2
g2m.agent
255 Views, 2 Replies
Basically, I want to build the face_offset sequence. this is my python code:
size = 18 # array_size(face_vertex)
max_iter = 6 # max_iterations
i = 1 # current_index
res = [] # result.
while i<=max_iter:
    n = int(size*(1/max_iter)*i)
    res.append(n)
    i += 1
print(res)
# [3, 6, 9, 12, 15, 18]
this is my graph:
The result should be as above: [3, 6, 9, 12, 15, 18]
But one value is wrong, why? ? [3, 6, 9, 12, 14, 18]
2 REPLIES 2
mjcg91
in reply to: g2m.agent
This is probably related to float rounding. Have you tried converting the one_over result to int before multiplying?
You could also use a sequence_array node to do stuff like this.
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
g2m.agent
the one_over result is sometimes 0.1111, after the integer becomes 0
I use divide instead of one_over to get the correct result.
sequence_array is fine too. Thank you.
