Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Face Offset & Face Vertex from Get Mesh structure
10 REPLIES 10
Message 1 of 11
moiamy
769 Views, 10 Replies
In the excellent demo of "Bifrost Visual Programming Masterclass - Part 1 of 2", I dont get why he doesn't take the (face offset) & (face vertex) output from the (get mesh structure) to plug directly inside the new (construct mesh)as the structure is identical ?
Tags (1)
Labels (1)
10 REPLIES 10
Message 2 of 11
g2m.agent
in reply to: moiamy
Because he needs to separate each face, similar to reverse "merge vertices".
Message 3 of 11
mjcg91
in reply to: moiamy
@moiamy You are correct, The new face offset is identical to the previous one. There is no need to re-generate the face_offset in this case. Only the face_vertex has to be re-generated according to the new point positions.
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
Message 4 of 11
moiamy
in reply to: mjcg91
Indeed @mjcg91 face_vertex needs to go through a new sequence_array
Still a bit confusing for me
I guess when I will find a way to check in detail data inside output array I will understand better...
Message 5 of 11
moiamy
in reply to: moiamy
Pushing further my undertsandings about this part, I would like to understand the [Access Offset Array] Compound.
So here is a basic drawing I made
If we enter inside [For each] compound, there is the [access offset array]
Is this computation correct ?
If  [Input] current_index ==0
           [Access Offset Array] start = [input] face_offset [0]
            [Access Offset Array] end = [input] face_offset [1]
Message 6 of 11
mjcg91
in reply to: moiamy
Yes that's correct. The face_offset defines the range of face_vertex per face. Basically it defines how many face vertex are used by a face (length), and where in the face_vertex array the first face vertex of this face is (start). With these data you can use it to slice the face_vertex array and get all the face vertex indices of a specific face.
Message 7 of 11
moiamy
in reply to: mjcg91
Actually there is a substract operation in the [access_offset_array] compound.
So shouldn't it be
    [Access Offset Array] end = [input] face_offset [1] - 1
Message 8 of 11
mjcg91
in reply to: moiamy
I wouldn't worry about how the access_offset_array works. It just gives you what you need to access per face / per strands data in Bifrost. Most of the time you only need start and length. end is usually used along with the slice node.
If this can help, I made this offset visualization for my Bifrost Strands blog post. The face offset works the same except it defines the face_vertex elements for each faces.
Even though its post about strands, you can learn more about offset arrays here.
https://maximejeanmougin.com/2020/09/08/bifrost-strands/
Message 9 of 11
moiamy
in reply to: mjcg91
@mjcg91
Did you use Manim for the animation ?
Message 10 of 11
mjcg91
in reply to: moiamy
I made it with Bifrost 😅
Message 11 of 11
moiamy
in reply to: mjcg91
Write a book Maxime... it will be sold out in one week !
