Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Extracting a range of indices from array containing 300 elements
1 REPLY 1
Polytikal1
162 Views, 1 Reply
I am attempting to texture elements of an alembic. I wanted to import it via graph editor in order to more easily adjust speed and start time with time_warp node, but I'm faced with a texturing challenge. I need to separate groups of elements associated with various textures, but it's very time consuming to do it individually. I've searched online and tried to apply some suggestions like using "within bounds" and all true from array to set a range of indices that I could then group in build array, but I'm missing a step in my understanding. I keep running into promotion errors. Can anyone provide an example of how you might setup a graph to separate ranges of indicates from an array with hundreds of elements in order to more easily texture each group, rather than individual elements? Thanks.
1 REPLY 1
Roland.Reyer
in reply to: Polytikal1
Hi @Polytikal1 ,
to get some elements from an array you can use "get_from_array".
To keep all other elements there is a "remove_from_array" node..
