Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
export simulated fibers as alembic sequence to import as animated curves but...
1 REPLY 1
marcury
597 Views, 1 Reply
seems when import the alembic sequence only can import one by one , any way to export the fibers as animated curves in 1 alembic? the point is try use fibers to drive xgen or yeti guides instead of nhair system
1 REPLY 1
Bifrost does support importing and exporting animated geometry using Alembic. When exporting, you have to tick `Write single file` on the write_Alembic node. If you don't have this option, you need to update to the latest version of Bifrost. For importing, you need to use the read_Alembic node and make sure you have the frame connected to the frame port in the time node. You also need to make sure that the frame_rate port is set appropriately.
