Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
do_while question
1 REPLY 1
g2m.agent
295 Views, 1 Reply
do_while question
I read this post about iteration and tried the do_while loop by myself, but I was confused.
https://forums.autodesk.com/t5/bifrost-forum/how-to-increment-a-value-inside-iterator-or-for-each-lo...
My graph should look like this:
v=5
i=1
while v<20:
    if i>5: break
    v+=v/2
    i+=1
print v
# result: 22
but my graph gives me: 33
1 REPLY 1
mjcg91
in reply to: g2m.agent
The loop_condition control if the loop will iterate again after the current iteration, not if it should start processing the content of the loop, so the output values are pulled even if loop_condition is false. Let's break this down:
at iteration n°4, value = 15, so it will loop again after the current iteration. you add 7 to 15 so the output =22.
at iteration n°5, value = 22, so it will stop looping after the current iteration. you add 11 to 22 so output = 33.
So the final value is 33, which is correct.
Here's what you can do:
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
