Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Delete volume points with manipulator field
3 REPLIES 3
rstefan
248 Views, 3 Replies
I want to ask if it is possible to delete points created inside a volume using
Roland Reyer's manipulator field and, if yes, how to proceed. In my graph, everything works fine,
but in the end, I would like to transform all instances into a single mesh using mesh to volume>volume to mesh.
As you can see, geometry is also built in the remaining points outside the manipulator.
I tried to connect the manipulator to the density weights port of the scatter node, and it's working, but with points generated on a mesh, not in volumes.
3 REPLIES 3
rstefan
in reply to: rstefan
Problem solved using cull points - I didn't even know this compound existed
sepu6
You can also connect directly to the create_instancer node without the cull point
rstefan
in reply to: sepu6
Thank you sepu6 , I really don't understand how I missed this - it was obvious
