Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Delete or kill particles
4 REPLIES 4
jalixko
885 Views, 4 Replies
How can I delete particles under de 0 postion Y axis using BFG?
4 REPLIES 4
joostkonemann
in reply to: jalixko
You can use the simulation bounds input on the particle_solver_settings node (the bounding box of the input mesh will be used to define the bounds). Or change the property_kill_points compound a bit to use the y position as criterium, see screenshot.
MacBook Pro 13,3 - 2.7GHz - 16GB - Radeon Pro 460 - macOS Catalina 10.15
jalixko
in reply to: joostkonemann
Thanks, the bounds option works fine.
Now I am trying to add mor emitters to my scene.
I could combine both objects , but I would like to know the way to add more emitters object to the Bifrost node graph.
Christoph_Schaedl
Ports with three dots are fan in ports.
Just plug in a second object into the same port.
https://linktr.ee/cg_oglu
jalixko
in reply to: Christoph_Schaedl
Thanks.
