Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
deform array(better translate array) on a specific axis
12 REPLIES 12
Message 1 of 13
darioOrtisi
1224 Views, 12 Replies
Hi all. I will like to deform array, The basic are my sequence array in white and i will like to translate progressively on a specific axis in world space. With this I fake deformation.
Thanks to anyone can help me.
12 REPLIES 12
Message 2 of 13
g2m.agent
in reply to: darioOrtisi
maybe use evaluate_fcurve node
Message 3 of 13
darioOrtisi
ohhh great. I supposed was that but i missed the connection between. 🙂
Thanks @g2m.agent
Message 4 of 13
darioOrtisi
It doens't work. My sequence array have a math/float3 on the step value. If i use a default it work but with my none. So i've added a vector3_to_scalar for each value i get but it doens't work too the curve evaulate only a portion of the points.
Message 5 of 13
darioOrtisi
Ok it works. Simply transform to float 🙂 stupid me
Message 6 of 13
darioOrtisi
Not as I wish.
The first, it is complicated to distribute on basic branches maintaining the direction i want so I want that the distributed brances,(strands or arrays) are on two sside. And when i rotated there is a problem.
Message 7 of 13
darioOrtisi
Solve this But i have another question.
When I use the fcurve i can get the shape of my "array deformation/translation" but if the array go over a certain range it continue to take the shape from the fCurve and this is a problem. How to fix it in a certain range?
Message 8 of 13
darioOrtisi
I miss to post other screeshot.
When the array size increases the shape change., So i mean there is something to lock the shape per length(i think)?
Message 9 of 13
g2m.agent
Maybe not the best way, but it works.
change_range to 0~1, fcurve, change_range back.
Message 10 of 13
g2m.agent
I think this should not be your final solution.
Because the points of fcurve are distributed on the X axis, they are not evenly distributed on the curve.
Message 11 of 13
darioOrtisi
@g2m.agentThanks.
After I create the strand i resample it so i have a better distribution i Thought.
Message 12 of 13
g2m.agent
construct_strands -> resample_strands -> get_point_position -> construct_points?
Message 13 of 13
darioOrtisi
Thanks @g2m.agent  it is.
Anyway this is the first time I've opened HoudiniFX and there is a tree and branches and leaf generator that I didn't know existed. Wow.
First tree. I must say that I'm starting to get discouraged a lot given my lack of technical knowledge. Because there is a lot to do and sometime all changes because an a wrong interpretation of mine. 🙂
So i don't know.
