Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Create instances array with the simple offset
1 REPLY 1
inegvin
290 Views, 1 Reply
Hi! I've only started to learn Bifrost and I've stuck with a quite simple task. I need to create a few instances of my input object with a simple vertical offset between them. Most of the tutorials show scattering or use another mesh as the points for positioning instances. I do not want to scatter the object, but simply make a stack of it, controlling quantity and offset (like a book's pages). What is the best way to do that?
1 REPLY 1
mjcg91
in reply to: inegvin
you could use sequence array with a Math::float3 data type. You define where is the first position, the offset (step), and the number of objects (size). Then  you can feed this into a construct_points to turn it into a point cloud object. Like this you'll be able to use it with the instance related nodes.
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
