Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
[CRASH] Rendering Alembic with bifShape node
0 REPLIES 0
Message 1 of 1
334 Views, 0 Replies
I am trying to render the alembic file read using the read_Alembic node in a bifrost graph and Maya crashes with the below Arnold stack-trace. I'm assuming this is not yet implemented in MtoA for the bifShape node type for alembic geometry and only the implicit bifrost geometry is currently supported? I guess MtoA should at least skip the translation in such cases or error out instead of actually crashing Maya.
signal caught: SIGSEGV -- Invalid memory reference
Stack trace:
/lib64/libc.so.6(+0x15ab97) [0x7fdb2787eb97]
AiArrayConvert
CreateMesh(char const*, ProcArgs&, std::vector, std::allocator > > const&)
ProcessExpObject(ProcArgs&, std::vector, std::allocator > >, std::string const&)
/usr/autodesk/bifrost/maya2019/2.0.1.1/bifrost/arnold-5.3.0.0/libarnold_bifrost_impl.so(+0x8d099) [0x7fd9d2813099]
/home/sshrestha/apps/arnold/mtoa/3.3.0.0/2019/plug-ins/../bin/libai.so(+0x86dc8b) [0x7fda69fe7c8b]
/home/sshrestha/apps/arnold/mtoa/3.3.0.0/2019/plug-ins/../bin/libai.so(+0x91d2e5) [0x7fda6a0972e5]
/home/sshrestha/apps/arnold/mtoa/3.3.0.0/2019/plug-ins/../bin/libai.so(+0x8e780f) [0x7fda6a06180f]
/home/sshrestha/apps/arnold/mtoa/3.3.0.0/2019/plug-ins/../bin/libai.so(+0x8e5a0f) [0x7fda6a05fa0f]
AiRender
/home/sshrestha/apps/arnold/mtoa/3.3.0.0/2019/plug-ins/../bin/libai_renderview.so(+0xa88a1) [0x7fda68a988a1]
/home/sshrestha/apps/arnold/mtoa/3.3.0.0/2019/plug-ins/../bin/libai_renderview.so(+0xa9d1e) [0x7fda68a99d1e]
/lib64/libpthread.so.0(+0x7dd5) [0x7fdb27af8dd5]
clone
Some background info - I'm essentially building a small compound that can update uvs by reading the latest alembic model file with uvs and setting the same on the animated alembic cache. So sort of a layered alembic support via bifrost.
Cheers,
Sachin
0 REPLIES 0
