Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Converting instances to real meshes
4 REPLIES 4
labbejason
1636 Views, 4 Replies
Hey guys,
I have a graph that takes a bunch of meshes and transforms then instances those meshes to said transforms. This creates a bif and works wonderfully. These instances belong to an asset, so I'm trying to temporarily convert the instances to actual maya meshes so that I can cache them together with the rest of the asset's meshes as one file.
I know it's not ideal and I should probably just cache them directly from Bifrost, but then I would have 2 cache files for a single asset. A lot of back-end stuff would have to be changed to support this, so for now I'm trying to avoid major pipeline changes.
The issue is that I'm getting nothing in the viewport when I connect my bifrost board's output. I'm following this link to convert them, and it works fine when I output normal meshes. So I'm wondering are instances able to do this too?
My node editor looks like this:
Out instances port is an array of amino objects and does display in the bif.
Labels (1)
4 REPLIES 4
mjcg91
in reply to: labbejason
BifrostGeoToMaya only works with mesh.
You could use this compound I posted a few days ago. It takes a mesh and distribute it on points, but output a single mesh instead of instances. If you have multiple input meshes, and are using a pointID property to define the meshes's  distribution, then you could easily add a mesh selector inside the for-each loop
https://forums.autodesk.com/t5/bifrost-forum/replicate-mesh/m-p/9685326#M2721
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
labbejason
in reply to: mjcg91
Thanks Max, looks like another question you answered helped me out here!
I was able to merge all input meshes then throw them into a `for_each node` with all input transforms. In there transform the mesh with your linked answer to output an array of meshes. Then luckily in my case I don't need them separately so at the end I do a final merge and send it to the top-level output. Now passing it to a bifrostGeoToMaya node works.
Top-level graph:
For each loop graph:insts_to_geo_for_each.jpg
Thanks again!
moiamy
Actually there is a out-geometry port in node editor if you use assign_material node, but sadly it doesn't work. No trick for 2023 ?
sepu6
What exactly does not work? Confused about what you are asking here.
