Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Convert to volume node - Mesh error's
1 REPLY 1
asinfield
459 Views, 1 Reply
I've been following a retopology tutorial in Bifrost:
https://www.youtube.com/watch?v=p6EuH5o_CuQ&t=119s
Now my mesh is direct from marvelous designer and is a welded triangulated obj. When i use the 'ConvertMeshtoVolume' node, i instantly see an error with parts of the mesh shooting off to the right.
I've noticed decreasing the detail size does slightly fix the issue, but it will always remain + my PC really doesnt like it!
I've tried playing with the bandwidth also, but couldn't improve on it at all.
Does the issue stem from a triangulated mesh? Or is it because it has holes in the geo?
I'm really struggling with this, hopefully someone has had a similar issue.
1 REPLY 1
Are you running the mesh to volume conversion in "solid" or "shell" mode?  Given the kind of mesh you're inputting, ensure you are in 'shell' mode.  That is not the default, I believe.
