Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Connect in series (or parallel but unconnected)) multiple Bifrost Graphs to create a single multi-mesh composite scene for rendering
2 REPLIES 2
anthony6UVHQ
337 Views, 2 Replies
Some guidance would be appreciated:  I'm attempting to composite several bifrost graphs into one .mb scene.
TWO ISSUES:
1. How best to input different meshes each into a separate bifrostgraph, to develop a composite scene from unconnected i.e. parallel multiple bifrost graphs. E.g. would be to input a "character" in each separate bifrostgraph rather than putting several "characters" with different program instructions into one complex mesh.  It is analogous to layering. Given a single scene with several meshes perhaps someone can explain how best to setup the Outliner to  display each graphical output separately, or any selected  subset of outputs, in the viewport. It seems that all meshes are present on all bifrostgraphs even if CNTRL H is executed to hide.
2. How to connect sequentially multiple bifrostgraphs  e.g. connect output of graph 1 (mesh) to the input of graph 2 sequentially with appropriate bifrost instructions.
Tony
anthony@artclebre.com
www.artcelebre.com
2 REPLIES 2
bugsdabunny
in reply to: anthony6UVHQ
You can connect graphs and pass objects between graphs using the Node Editor. I think this is what you are trying to do in the screenshot below. I have one graph where I add some noise to a sphere. Then I pass it to bifrostGraphShape2 and move the sphere up 5 units and color it red in the second graph. I can hide either graph by selecting it and setting visibility to 0 by using the Ctrl+H shortcut; I'm not sure why that's not working for you
anthony6UVHQ
in reply to: bugsdabunny
Thanks. I didn't think about the node editor...too much focus on bifrost programming!
Tony
anthony@artcelebre.com
www.artcelebre.com
